Posts: 1,005 Likes: 5
Posts: 1,005 Likes: 5 |
What is the best way to clean the inside and outside of a mechanical fuel pump before rebuilding it?
I glass bead blast them. Others use carburetor cleaning solvents.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I have seen bi carb soda used in a "glass bead" unit, not as harsh on the alloy leaving a smoother finish. Tony
Posts: 217 Likes: 3
Posts: 217 Likes: 3 |
Also, if any media remains it will simply dissolve where sand or glass bead might find its way somewhere that could be destructive. I use soda for carburetor work also. Jeff
Thanks. I appreciate the help.
