. To save a few pennies, many auto manufacturers used the Left and right rear brake lights for the turn signals. You will need to add one wire from dash to brake light. Also a wire from the stop light switch to the signal switch. If you use separate lights for signals, you will need to add two wires to the rear. .
. In front, the parking lights are not bright enough to use for turn signals so you need to add 15 candle power (CP) or greater bulbs to additional fixtures or in some cases in the late 1940s 1154 bulbs can be added that have 3 & 21 CP to the existing sockets. .
. If you have a 1932 coupe and want to use the cowl lights, use 209 bulbs for 6 volt or 1003 bulbs for 12 volt. Separate the right and left wires. If you want to use cowl lights for parking lights as well, a circuit with two diodes and a separate switch will allow you to illuminate both cowl lights. (No details here.) .
. I assume you have a 7 wire turn signal. A 4 wire uses separate turn light fixtures front and rear. .
Lou .
