Posts: 10 |
changing the inside part of the cable and I'm thinking about using never seize as a lubricant or should I use something else , what do you think ?
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
It would be a little stiff, for my taste. I don't know how it reacts to cold temperatures. Speedometer cable and vacuum wiper lubes should stay soft when temps drop.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Do not use it for that purpose. It is not designed to lubricate but rather put a barrier between parts to prevent "seizing". Either graphite or lithium would be my choice.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I use white lithium assembly lube.
1 member likes this:
Clement |
I no longer use white assembly lube. Had two engines where I used that froze and crankshaft wouldn't turn after a few years. Took them apart, all looked good and rotated when the hard white lube was removed and 10-W 30 oil was used.
I think your local auto parts store will have a specific lube for speedo cables.
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
Should be able to use vasolene. My '36 says to use that on the Dubonnet spindle shaft.
