Hi guys,
When I bought my car, completely torn apart, it came with 5' long double beaded window run channel and fuzzies. I bent and glued the window run channel around the top of my doors and down the sides and the windows worked great, until I tried putting my garnish mouldings in. Im realizing that the window run channel is too wide to let my mouldings fit against the frame of the door...
I guess my question is: Did these cars only use fuzzies attached to the garnish?
Thank you.
