Posts: 1 |
Where is the best place to find adjustment instructions for my vacuum shift 1947 Fleetmaster?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Welcome to VCCA Chatter. I'll move this to a technical forum for you.
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
The adjustment procedure the vacuum shift valve as well as the associated linkage is described in detail in the shop manual. A copy of the 1941 Shop Manual (similar to 1947) is available on line at Oldcarmanualproject.com. This link may help. Mike https://chevy.oldcarmanualproject.com/1941shop/41csm214.htm
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
You can also use Advanced Search with this string: +adjust +vacuum +shift . The "+" means that the each word must be in the post but not necessarily in that order. Leave a space between each word. You will see quite a few posts about this.
My search returned 200 results which I think is the maximum Chat will return.
