Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
I need a passenger side garnish moulding for a 1934 or 1935 Standard coupe. It is possible that a moulding from a 1933 Master/Standard or 1934 Master, 3 window coupe would fit but I cannot verify this. If you have something that is a possibility, please contact me. I can do a template from the drivers side to determine if it will fit. Thanks.
Mike 573 864 6539
The door glass for a 1934 1935 Standard coupe is listed for those model years only lso I believe the garnish moulding would be limited to that applicatio only also.
Gene, That makes perfect sense. I have some mouldings from a '35 Standard 4 door. I think they could be used to piece together one for the coupe. The radius at the top rear of the door does not match any other radius. The top rear of the rear quarter glass is close but not the same. I think a talented fabricator could make it happen if it comes to that. Thanks for the observation.
