Edmond Offline OP
My car is a 1930 4-door sedan.
When we pulled the car out of the barn, the carburetor was missing as well as the connection to the throttle knob. Would anyone be kind enough to send me a photo of the assembly connecting the carburetor to the throttle button?
Thanks for your help,
Edmond
Edmond
here is photo of "G" Gas cable (upper cable) as it connects to the carburetor. The lower cable it the "C" Choke cable.
Edmond Offline OP
Thank you,
And how is the control coming from the foot button fixed, please ?
Edmond
Edmond Offline OP
I see the metal rod behind the exhaust outlet in the photo. I would like to know how it is attached on the carburetor and on the foot pedal.
Thank you for your help.
Edmond
OK, sorry for delay, been crazy here
here are a few pictures from my 1929 accelerator pedal to the carburetor. shows accelerator return spring (returns carburetor to idle when you lift of pedal) that runs from the carburetor (accelerator arm) to the near exhaust manifold stud. also shows the anti rattle spring (keeps accelerator arm from rattling around on the carburetor lever) and washer (security to keep spring in place) that goes on the accelerator arm at the carburetor.
and YES the accelerator pedal rides on the wood floor :)
20180716_110710.jpg 20180716_112841.jpg 20180716_112859.jpg 20220215_181702.jpg
1 member likes this: Clement
Edmond Offline OP
Thank you very much !
Edmond
You are welcome, let me know if you need anything else
