#486890 11/11/23 04:32 PM
John_C Offline OP
Hello again,
I just received a replacement fuel line that goes between the fuel pump and the carb. If I recall, doesn't the original line have flared ends?
I'm attaching a photo of the new fuel line from The Filling Station. Are there any special instructions I should know when installing this new one?
Thanks!
Member #50432
NO flared ends on the 29-31 they used compression fitting like you show
that kit looks correct, i recently made new lines for my 1929 and copied what was there.
here are a few of the same line from fuel pump to carb on my 1929 i made
John_C Offline OP
Great! That helps. I’ll be installing it soon.
Member #50432
