I have heard that this is the best way to adjust your valves. How do you keep the screwdriver in the slot with the valve going up and down?
Practice. I have done it. Idle a low as you can.
J Franklin
As J Franklin suggests practice and more practice, I adjust valve clearances that way most times.
There is a tool for this. Go to eBay and search "valve adjusting tool". The Snap-on allows the use of a socket for the nut while the captured screw driver handles the set screw. The Zim is self contained and is made to accommodate two different nut sizes.
I have a hand full of them.
I have only used an ordinary flat blade screwdriver and appropriate sized ring spanner, though the earlier Subaru engines did require a special tool.
