Posts: 89 Likes: 1
Posts: 89 Likes: 1 |
let me see where this goes.
I understand that GM came out with a 6 volt 4 field starter in late 53 (Delco 1929912) It was intended for use in the 53 and 54 Power Glide equipped cars. I know back then the PG cars had a higher compression ratio engine, and having a few more horsepower than the standard shift models. I am thinking the new starters, with the four fields, was designed to assist in starting the engine by producing a greater amount of torque than the older 1107109 starter. I am curious to know if this is a correct assumption, and if so, how great of a difference would that make in cranking over the engine? Also, would it not follow, that if a starter developed more torque at the same voltage, that it would result in an increase in the amperage draw necessitating somewhat heaver wiring?
I started thinking about this because I am considering installing a 261 in a car running on 6 volts. I would rather not switch over to 12 volts. I believe the compression ratio of the 261 (7.8:1) would be similar to, or even slightly less than the compression ratio of a 235 with an 848 head (8:1). I don't think an increase of cubic inches would have much of a difference in terms of the required torque. If all this washes, then I'll get more serious about finding a 4 pole starter and pursuing the 261 installation. I am a long way from being an engineer so I would be eager to hear the opinions of those having more slide rules and experience than me.
You are correct in the fact that Chevrolet had a 4 field starter and it performs better than the 2 coil version. I am not aware that it requires any altered wiring. Gene will be able to provide much more knowledge based on his experience.
The 1954 Power Glide had a 4 field generator. it had number 1108035 stamped on the tag.
After, 1954 the parts book listed that number as a replacement for 1950-1954 Power Glide models.. When new the 1952 models were the only models that had the not turning over when hot - that I remember.
In 1952 they removed all the copper they could due to Korean war shortages......including radiators and starters.
Posts: 65 Likes: 1
Posts: 65 Likes: 1 |
Is there an easy way to tell if a starter has 4 field coils vs 2, without disassembly? I have seen some for sale with the 1108035 tag, but I hate to purchase without knowing for sure it is truly the uprated starter motor. The 1954 Power Glide had a 4 field generator. it had number 1108035 stamped on the tag.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
check your local auto electronic srebuilder. i had the 4 field coils installed in a 2 coil starter years ago, mike mccagh
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I expect that an ohm meter would should more resistance in a 4 coil starter.
Perhaps someone on chat who has both could make comparison readings.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I think the 2 pole units only have 2 screws visible from the outside to hold the pole pieces in place while the 4 pole would have 4 screws. Tony
