Posts: 56 Likes: 3
Posts: 56 Likes: 3 |
Hi All, I am working with a 6 volt generator and a 3 post voltage regulator and need to know the wire gage size that is used to connect the field and the armature from the generator to the voltage regulator. Thanks in advance.
I did not stop to see which terminal is for but the center terminal in 10GA and the outer is16,
