. Most spring companies can make spring leaves if you provide length, width, thickness, arch and end configuration such as rolled. It's difficult to find 1-3/4" wide springs in stock today. When you remove your rear springs, either add or remove a leaf so both springs are the same. If your springs are just saggy from over use, you can get them re-arched. Coil springs are more difficult to have made than leaf springs. Newer trucks with leaf springs use wider thicker but less leaves. One year the Chevy II had only one leaf in the rear spring but no torque tube. Too much axle wrap caused problems.
. Good luck, . Lou
