I need to buy a new rebuilt water pump. I see there are two sizes, a short and a long. I think I have a long pump as it measure 2 1/2” I am looking for confirmation that a 39 master deluxe did use a long pump vs someone just putting it on in the past. In addition does anyone have a contact for rebuilding the pump
If you look in the Master Parts list you will see a comparison of the 3 pumps for '37, '38' and '39. As Gene noted, the '39 pump was the service part for '37 & '38.
. I recall reading the monthly updates (Wrong name) that the first two bushing pumps were being replaced with the permanently sealed bearing style pump. This is confirmed by the foot notes at bottom of this page. . . There is a slight difference in length which is also on this page. I know that the fan is quite close to the radiator and one has to be careful when installing the radiator shell so the fan doesn't eat the radiator. . . . Lou .
