#485588 09/21/23 06:51 AM
Tiny Offline OP
I have an old glass sediment bowl in-line fuel filter that I've been thinking about installing ahead of the carburetor in wake of my RTV in the float bowl saga, hoping to stop any more that might try to migrate. The issue I'm having is there's no room to mount it in the straight leg ahead of the carb with the bowl down. It hits the air filter housing if I try to place it next to the carb and won't clear the horn if I try to place it further forward. It will fit if I put the bowl on top instead of the bottom. Other than dumping gas on the engine each time I remove the bowl, is there a downside to mounting it upside down? I may just mount a modern glass in-line filter and save the hassle.
Tiny #485592 09/21/23 07:51 AM
Could you put it before the fuel pump? I had one there on my 39 for many years when it wasn't being used regularly.
Tiny #485595 09/21/23 08:38 AM
Online Happy
I would use the inline filter. With the glass bowl upside down I think if there is sediment it will be stirred up whenever there is gas flow. In the normal position the sediment settles in the bottom of the bowl and I think pretty much stays settled.
Tiny #485599 09/21/23 10:28 AM
Hi Tiny
On the original style fuel pumps for 216's, the glass bowl IS upside down, right? 🙂
The pump bowl was of course designed to work that way, but I would think yours would still filter properly.
Probably the main downside would be that water would no longer settle out in the bowl and be visible... but you don't have that feature right now anyway. 🙂
PS
As well, any material filtered out would lay directly on the screen and stay there.
That would mean you would need to watch the bowl and maybe service it more often.
But you are only looking to trap "big stuff" right?
So that still shouldn't be a big problem.
Ole S Olson
Tiny #485600 09/21/23 11:53 AM
Actually the particles fell to the bottom as the incoimg gas pushed them away keeping the top of the super fine screen clean.
With every tune up the bowl was removed and the area on top of the pump cleaned-up.....usually with compressed air . The bowl gasket was cork and in the ;later years changed to neopenen We stocked hundreds of them in the parts department.
Agreed
I was referring to the way a glass bowl fuel filter designed to hang down would work if turned upside down.
Then the particles would lay on the screen... correct?
Ole S Olson
Tiny #485602 09/21/23 01:00 PM
Attached is a screen shot of the filter I installed on my 41 prior to the cab. I also have a glass inline one prior to the pump. I had the one prior to the pump since we replaced the tank. We added the one prior to the carb when we replaced the carb. We had to make the line just a bit longer. Having two filters has caused no issues for us. I have never seen sediment in the on by the carb. The modern inline type I do see a few black bits of junk but nothing major. One advantage to having a glass filter in both spots is that I can see if fuel is getting to the engine when trouble shooting it. Also both allow me to see the condition of the filter.
Tiny #485683 09/25/23 10:19 AM
Tiny Offline OP
Hopefully problem solved in respect to RTV getting to the float bowl.
Tiny #485685 09/25/23 10:49 AM
Hi Tiny
Must have been a little hard to get yourself to cut a piece out of your fuel line. 🙂
Off topic but... where did you get your wiring harness? Looks really nice and original, and I've been considering getting one for my truck.
Ole S Olson
Tiny #485688 09/25/23 11:27 AM
Tiny Offline OP
I got my harness from YNZ.
1 member likes this: Stovblt
Tiny #485692 09/25/23 12:10 PM
Thanks!
Think I'll give them a call.
Ole S Olson
