We are finishing the dash rework on my friend’s 1970 Monto Carlo. The instrumentation includes the warning/idiot lights for oil pressure, generator (really alternator) and temperature.
The problem we are trying to solve is to prove the that temperature light is working properly. Right now the oil and generator lights come on when the ignition switch is turned the to “On” position before starting the car. The temperature light does not light. I cannot “force” the temperature light to come on by grounding the wire that attaches to the temperature sensor on the right (passenger) side head.
I think part of the solution is understanding the TCS that was originally the car. That system used a combination of inputs including engine temperature to control when a vacuum signal would be sent to the distributor. It was a very early form of emission control.
I have a shop manual and wiring diagram. I do not have access to an owner’s manual.
To make it more challenging the have been numerous modifications over the life of the car. The engine is a 350 from a 1975 Chevelle convertible based on the numbers on the pad on the block. The distributor is a more modern HEI unit. The stock manifold and carburetor have been replaced with aftermarket units.
I am not interested in re-installing the TCS. I simply want to prove that the temperature light is working correctly and will come on if the engine overheats.
Any ideas about what to check are appreciated.
