#485560 09/20/23 08:22 AM
minetto Offline OP
I was explaining to a friend the procedure for setting the timing on a 216 yesterday while reviewing a shop manual with him. In his case, a 1946 1/2 ton pickup, but my question is more general. He asked me where to set the octane selector after the clamp on the distributor was tightened and I gave him some guidance. He then asked me where it says that in the shop manual? After reviewing the 1941 and 1942-1948 shop manuals and a couple owners manuals I could not find any text describing the setting. My question is not what to set it at today with modern gasoline but where can I find the original Chevrolet guidance? Various Service Bulletins maybe?
minetto #485561 09/20/23 09:54 AM
Below is the 47 shop manual (they don't have a 46 but the procedure would be the same) and the 46 owner's manual.
https://chevy.oldcarmanualproject.com/shop/1947truck/47ctsm0618.htm
https://chevy.oldcarmanualproject.com/chevyowner/46om13.htm
minetto #485562 09/20/23 10:00 AM
minetto Offline OP
Tiny, I now see it in the owners manual. I would have thought there would have been a paragraph #4 in the shop manual saying the same thing. I appreciate you finding it and will pass it on to my friend. Thanks again, Mike
minetto #485563 09/20/23 10:04 AM
The original way no longer works with tudays high octane gas. t is impossible to get the engine to ping underload
Set octane selector to zero. Set timing as manual says. then advance the octane slector 6 to 8 drgrees advanced,. This is where you get the best overal performance......and use the lowest octane gas you can find.
A higher octane gas means the gas burns slower and nothing more.
minetto #485568 09/20/23 12:57 PM
The Octane Selector is nothing more than a conversation piece these days. Since vehicles of that era were made to run on low (by today's standards) octane fuel I don't even use a timing light. Once started and warmed up I set the timing to the fastest/smoothest idle then lock it down with the OS on 0. If necessary I can retard it a degree or two using the Octane Selector. It hasn't been necessary yet.
1 member likes this: Clement
minetto #485569 09/20/23 01:24 PM
I agree that the octane selector is just an interesting relic of a bygone era.
I also agree with Gene that it is almost impossible to make one of these classic engines knock under under load. due to highly advanced timing.
The limitation I determined was that with any more than about 13 degrees BTDC static timing the engine was hard to start due to "kick-back". This was especially noticeable when it was at operating temperature.
minetto #485570 09/20/23 03:53 PM
Years ago the octane selector allowed the owner to set the timing (advance or retaed) the tiing for the best performance for the gas he wa using due to the fact the octane varied from brand to brand Also we had no way of knowing what the actual octane was .
minetto #485575 09/20/23 07:09 PM
minetto Offline OP
Thanks for everyone’s feedback. When my friend asked me what did Chevrolet recommend at the time I was at a loss to find it. Mike
