Posts: 104 |
On some Chevs I’ve worked on there is a small vent on the top of the rear axle housing. I crawled under my ‘36 Master and can not find one. I’ve looked online at pictures of rear axle housings, and there doesn’t appear to be a vent. Is that correct?
Thanks, Matt
Matt
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
Check the top of the torque tube.
Going by the parts book 1952 was the first year and was not on the torque tube but on the rear housing - on the right axle housing tube.
I recall that we had a lot of rear axle seal leakage in 1951 and that may have been a core
Posts: 104 |
Matt
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
I have heard of some members having to add a vent if they replaced the axle bearings with sealed bearings. One solution is to drill a hole through one of the top bolts on the rear cover. Put a cotter key through it so it stays clear. Keep it off to the side opposite where the ring gear is so it won't get too much oil slung against it.
