Well, after several months of working on it, I finally got the '31 engine back together and running again. Is 7 psi oil pressure good enough? That is what I get at idle. Thanks to all who commented on mine and other members questions over the years. They really helped me in getting this far.
--------------------------------------------------------- Thanks much, Ralph "Roll Tide"
So, it has been a few weeks since I last started the engine. Got it running today, but after a minute or two, I had no oil pressure. Last time it ran I had 7 psi. Any thoughts on why?
No, that's what got me looking at the oil pressure gage. Back when I had everything apart (including the oil pump) and then put back together, I used a drill and adapter to prime the oil pump. Even then, it took priming oil through the oil distributor to get the pump woking. I am sure everything went back together correctly. I am using the correct recommended oil.
So, I did figure out that the oil pump lost its prime. I took the line loose to the rocker arms and poured some oil down that line. That did the trick and the pump is pumping again. Going to wait a few days and see if it still keeps its prime. Thanks for the help.
