Well, just when I thought I had things worked out, after I had left the ignition on by mistake a while back, I seemed to have fixed the no spark situation, thinking I might have fried something. Did get it running again but in the meantime, I thought I would replace the plug wires and the coil, not knowing how old they might be.
Got the new coil and wires and she fired right up.....but once warmed up a bit, dies out. One thing I did not replace was the old condenser.
Wondering if the new wires and new coil are revealing the condenser is malfunctioning or could be something else. Reset the points at .025, and the new coil is not overheating and I'm getting a spark at the points when I manually turn it over with the distributor cap off. I did loosen the distributor and turn it while the cat was running and smoothed out the rough idle, secured it, but as the car warmed up, she dies.
