#484840 08/29/23 04:58 PM
54-235 compression test
1- 78
2- 90
3- 90
4- 90
5- 90
6- 90
What do you guys think?
Bb54chevy #484841 08/29/23 05:11 PM
2 -6 are good. They are within the +/- 5 psi desired. I would first check the adjustment on the number 1 valves and also check to see if there is any indication of a sticky valve. If that is okay there is probably a leaky valve. If it were mine I would drive it to see if it gets worse or better. If the engine has not been run much lately there could be a thin layer of rust that might be at least part of the problem and with running might get better. Not likely but worth a try.
Bb54chevy #484860 08/29/23 09:59 PM
The compession for that engine should be at least 120 to 130 p0unds. Try a different gauge. I would run some ATF through the carb throat at a fast idle and see if that helps sickey rings or valves.
Bb54chevy #484862 08/29/23 11:04 PM
Squirt oil into the cylinders and run the compression test again. If the compression goes up significantly that will indicate poor sealing of the rings.
Bb54chevy #484921 08/31/23 11:46 AM
Okay I check compression with the vacuum advance disconnected and got some different results.
1-100
2-105
3-103
4-98
5-100
6-95
Bb54chevy #484926 08/31/23 01:21 PM
Disconnecting the Vac. advance has nothig to do with the compression. Opening the throttle is the only thing mentioned in the SHOP MANUAL.
Disconnecting the Vac. advance will omly cause a vacuum leak.
Diffeernt engine temps. and cranking speeds can cause it to vary along with squirting oil into the cylinders.
