#483828 07/29/23 12:43 PM
Hi
The arm on my brake light switch is getting a little loose. I was thinking of trying to replace it. The filling station doesn't show any. Any where i can buy a couple ?
Thanks, Cliff
not bad, yourself ? Thanks for asking.
Did the 32 not use a pressure switch?
1932 Chevy’s have mechanical brakes. 1936 was the first year that Chevy’s had hydraulic brakes. Some of the “higher end” GM brands had hydraulic brakes earlier than 1936.
Wasn't aware. I wonder if a more modern mechanical switch could be adapted? I put one on my 38 to replace the pressure switch.
There is several for sale on eBay.com at the moment
JACK
thank you Jack
1 member likes this: jack39rdstr
