#484626 08/22/23 05:10 PM
SeanK Offline OP
32 confederate in need of rear axle. I think there are two versions. 3/4 bolt heavy duty and a smaller version. Looking for the smaller version. Will consider full rear end as well. Thanks fellas.
Support The VCCA!
If you are referring to the axle SHAFT I may have one. Send me a PM (private message) with your phone number and I will give you a call.
SeanK Offline OP
How do I pm you. The @ comcast rejected (i am in IT..this embarrassing sorry)
I got the pm. Will check the shafts I have . I have two shafts but both have issues so hopefully someone has one in good condition.
