Posts: 144 Likes: 1
Posts: 144 Likes: 1 |
I am going with single exhaust on my 1950 Bel Air, 235 PG. Several vendors offer them. Any recommendations on vendors?
Posts: 535 |
I bought from Waldron Exhaust. Everything fit.
Posts: 1,005 Likes: 5
Posts: 1,005 Likes: 5 |
You should have ordered the exhaust system for a 235 engine becase all the pipes are larger in diameter amd muffler designed for less back pressure in your 235 engine.
The original exhaust pipe to manifold connection used a fLAT GASKET AND PIPE FLANGE in 1949 and 1950 and that did not work out well so replacements sold used the fat packing ring line previous and following years had
Gene, my '50 has a 216 engine.
