The Shell Lubrication Engineer obviously doesn't know old Chev engines.
Spay lubricated (pressure stream) Chevrolet engines are best lubricated with lighter oils.
And viscosity is one of THE most important qualities of engine oil.
Chev was actually quite adamant about this when these engines were being sold and used.
And, valve train pressures were quite low on 216's so high zinc levels aren't really needed.
Nor were high zinc oils used in these engines, and yet, here they are, still running.
When is the last time you heard of a 216 wearing out a camshaft?
A top quality detergent 0W-20 or 10W-30 would be a FAR better choice.
What ever you choose, enjoy your car!
Got any pictures? 🙂
BTW
Capacity will be 5 quarts plus whatever the filter holds.
