On a 31, it's not that hard to change. Drain the tank, put a jack under the tank and remove the fasteners. Disconnect the line and pull the tank out. The sending unit is held in place with a few screws. As long as nothing is rusted, I'd estimate 30 minutes. You may have to remove a tailpipe hangar as well. I didn't on mine since the PO put an aftermarket tank in that doesn't allow the hangar to be installed.
But before you go to all that trouble, try adding a ground wire from the tank to the chassis. That may be all that is needed.
