The cushion spring bottom has two round wire tabs on the rear that go into slots in the rumble pan reinforcement triangle support. The front of the cushion is secured in place with two straps of matching seat material that go under notched blocks and then have eyelets that go over a double headed nail/pin. The straps keep the front of the cushion from lifting and the blocks keep the cushion from sliding forward. I have pictures but it will take a little bit to get them posted.
