Posts: 43 Likes: 4
Posts: 43 Likes: 4 |
On my newly purchased 1948 Chevrolet Fleetmaster Woodie do I need to add a “Lead Additive” to my gas when I fill up?
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
No. The horror stories of valve recession due to no-lead gasoline are extreme exaggerations,
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
Hi Buckaroo
I don't think there are any "lead additives" left... only "lead substitutes".
I thought using one couldn't hurt and would just be extra insurance... until I realized it was very quickly depositing a coating on my spark plugs. My truck went from running well to idling poorly, to also running poorly at off-idle, and rapidly getting worse. I probably had the carburetor off 3 times before I finally changed out my almost new spark plugs and cured it.
I haven't used the stuff since.
Ole S Olson
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
X3 No. With the low spring pressure of these engines it'll never be an issue.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Lead in fuel wasnt used in 1948 so the engine wasnt built to use leaded fuel, dont waste your money. Tony
