Hi guys,
I installed some fenton headers on my 55 235 engine, and am wondering if going with a new pedal and cable setup is the way to go. Had to fab a new trans cover as I added a T5 transmission and open drive, so a new pedal is kinda mandatory. Anyone done this? Figuring a cable pull setup, replacing the rod push on the Carter is a challenge... Im sure some of you have done this? What did you do?
Thank you!
