41 Master Deluxe, 216. I have never done anything to the internals of the motor and do not know its history. I have heard that I should be running lead substitute, I have heard to run it once in a while and I have been told it is a waste on money. What is the truth and what should I do? I have been running it when I have it with me when I fill up, so every so often. Am I wasting the $10 a bottle? It is also getting harder to find on the shelves.
I have never used it in any of my old cars. If a $10.00 bottle only treats one tank of gas, it would also have to fix me breakfast before I would consider using it.
1 member likes this: Hendo
The compression in pre-WWII engines and many post WWII as well is below the requirement to prevent spark knock when using currently available 85-87 octane rating gasoline. In fact it is often necessary to increase the timing to receive the full horsepower in the engines designed to use ~ 60 octane fuel available when they were new.
There was no lead in regular grade in 1941.......lead was added to gas to make it burn slower in high compression engines to prevent pre ignition .
Yes.
Thanks for the information. I have been using the 90 non-ethanol gas and occasionally adding this for awhile. Going forward I will just use the non-ethanol gas and Stabil (anything I do not use weekly gets this in it). Wish they had the non-ethanol in 87 then I could save allot of money.
