#483436 07/14/23 12:56 PM
Bertus Offline OP
I need to make new door and interior panels for my '32. 1/8" thickness. Can anyone tell me what material was used back in the day, and some suggestions as to a good plywood or melamine or whatever is preferable today? Thanks.
1932 Chev 5 Window Coupe
Bertus #483453 07/14/23 11:45 PM
Water resistant upholstery cardboard is the base of interior panels. You can purchase the board from upholstery supply companies.
Bertus #483688 07/24/23 05:49 PM
I used 1/8" high density Masonite.... on several vintage vehicles... very strong and can be drilled or sawn easily.... buy it at most hardware or building supply stores...
1934 Chevrolet Master sedan
Bertus #483693 07/24/23 07:55 PM
A downside to Masonite is it's not resistant to water. Moisture will soften it quickly.
Bertus #483697 07/25/23 04:54 AM
There isnt many materials that are water resistant in water though most masonite and mdf are resistant enough for inside door card especially with a vynil covering.
