Posts: 412 |
I need to make new door and interior panels for my '32. 1/8" thickness. Can anyone tell me what material was used back in the day, and some suggestions as to a good plywood or melamine or whatever is preferable today? Thanks.
1932 Chev 5 Window Coupe
Water resistant upholstery cardboard is the base of interior panels. You can purchase the board from upholstery supply companies.
Posts: 349 Likes: 20
Posts: 349 Likes: 20 |
I used 1/8" high density Masonite.... on several vintage vehicles... very strong and can be drilled or sawn easily.... buy it at most hardware or building supply stores...
1934 Chevrolet Master sedan
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
A downside to Masonite is it's not resistant to water. Moisture will soften it quickly.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
There isnt many materials that are water resistant in water though most masonite and mdf are resistant enough for inside door card especially with a vynil covering. Tony
