Hello cms161150,
Your question brings about more questions than any positive answers that I could give. 'chevy.oldcarmanualproject.com' The 1929-32 Master Parts Price List, page 1 'motor' then page 9 'harmonic balancer' shows: U - Spacer, Harmonic Balancer 836356. U=1930. OK, 1929 only lists 'pulley, crankshaft'. 1930/31/32 each list harmonic balancers of different part numbers. 1930 is the only one that lists a spacer. Why is that? My guess (only a guess) might be because of 1930 harmonic balancers not being long enough installed so to be out of line with the fan pulley. With everything installed, you might check your pulley and belt alignment. If out of alignment, that would at least give a spacer thickness measurement. Hopefully, the 1930 folks can be of help to you.
