Posts: 6 |
What is the best thread sealer for head bolts that screw into the water jackets?
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Here in Aus GMH used a special sealer but Permatex non hardening is just as good, I dont use the little brush supplied but dip the lower 4 or 5 threads into the sealer. Never had any leak afterwards. Tony
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Loctite 1158514 is made specifically for that task. I've not used it but most likely plain old plumber's pipe dope for liquids & chemicals would probably work just as well.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Is it really needed? Charlie
I use Permatex No. 3 or Aviation grade. It lubricates as well as seals. Is it necessary not for some engines but is for others. Why take a chance? Besides the threads need to be lubricated to get the proper torque.
