Can anyone help? The manual says that the four bolts that retain the gearlever cover on the floor change gearbox has two special bolts to the front of the plate. Can anyone tell me how they are special and whether they are available anywhere please?
The two front bolts which hold the shifter main plate to the gear box housing are bolts which lock the 2 shifter slide rods in place , at the front of the gearbox, so do 2 jobs, hold the cover assembly down , and keep the internal shift slide rods in place.
JACK
