#482869 06/21/23 09:23 AM
Augie Offline OP
The outside door handles on my truck are loose and drop down. Are there springs that hold the handle up or something else? TIA.
Not sure about a 36 truck but my 33 coupe has a spring inside of the door latch mechanism. I would think they are a similar design.
Ed
You have a weak or broken spring or excessive wear. Both can be remedied. You probably have got this fixed by now, I didn't notice the age of your post!
J Franklin
