You need to select the electric fuel pump carefully. First of all, which voltage?
The most important factor is the making sure you have a way to control the fuel pressure to the carburetor. Pressure over 5 psi could create problems by pushing the needle valve off the seat and flooding the fuel bowl.
Are you having problems with the mechanical fuel pump? Most of us have run them for years with no issues. Most of the time any problems can be resolved by a simple rebuild. Also, if you have a dual diaphragm fuel/vacuum pump those are hard to find.
Booster Fuel Pump
