#482453 06/06/23 07:28 AM
My 41 SD has full carpet front and back. The front has a heel pad in rubber/vinyl. I've added cheap rubber floor mats, but looking for something a little nicer. Any ideas?
I'm guessing the carpet is wrong in the first place, but I'm ok with it. Should I just try to find an upholstery shop to make me some floor mats in a coordinating material? All I've been able to find is what I think to be more original (a full rubber mat with small carpet inserts).
The SD had a brown ribbed rubber mat with a carpet insert on each side with the left side insert being shorter and and extending only coming about up to just below the pedal pads.
They were being reproduced at one time,
Thanks Gene. I figured my nice plush carpet wasn't of the original style. I'm happy with it, just trying to find some mats to keep it clean for longer.
