Going to install my distributor on my 1928 National.
- I have the #1 piston at TDC - both intake and exhaust valves are fully closed (the lifters and push rods are at their lowest position)
- Timing marks on flywheel are visible in the window
- firing order is 1-2-4-3
I know the distributor has to mesh with the timing cam shaft splines and the bottom of distributor has to mate with top of oil pump.
My question is, where does my rotor have to point EXACTLY on top of the distributor?
see attached pix of my distributor
Thanks, Todd
Most distributors I have on 4 cylinders locate the rotor at the notch for the cap. It is my opinion that the factory located it in that position. That positions the number one spark plug wire at the notch. Then be sure that the body can be rotated clockwise 15-20 deg. before the grease cap hits the block. That permits adjustment of enough advance.
2 members like this: verng, Dave39MD
Without the pushrods installed, how do you know both valves are closed?
Mike Quezada
(559) 250-5427
mike.quezada@M2ProSol.com
Unless you can see the camshaft lobes you do not know if #1 or #6 is firing.
With a four cylinder I do not think he should worry about it firing on #6.
Oops!
Here's how I installed Lurch's distributor when I rebuilt his engine in 2017: https://vccachat.org/ubbthreads.php/topics/400583/re-resurrecting-a-28-4-banger.html#Post400583
Ray Holland also provides instructions for installing the distributor in his "School is in Session" document. This wonderful book covers his built of a 1928 engine. The document is a PDF that resides in the list of Technical Articles in the Members area off of the VCCA's main club page at vcca.org
Hope this helps. Dean
Support The VCCA!
Member Photos
1964 Chevrolet Impala SS
by DreamChevy, February 17
My 1933 Chevy 2 Dr. Sedan
by 1939Chevy1, November 24
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
Who's Online Now
3 members (Oldiron, NeilA, jp49), 57 guests, and 21 robots.
Key: Admin, Global Mod, Mod
Newest Members
18,308 Registered Users
Today's Birthdays
aristech, RalphL, tonysk
Forum Statistics
Topics59,069
Posts429,046
Members18,308
Most Online1,133
Jan 22nd, 2020
