#482230 06/01/23 10:32 AM
I noticed that the '32 parts book lists different parts numbers for the wheel well braces for '31 and '32. Can anyone tell me the difference or better yet, provide a picture?
I'm not sure about the numbers but I recently received a set from the filling station. You might check with them.
Tim, the difference may be due to the wider wheel well fitted on 1932 front fenders the 1932 would need shorter brackets, 4:75 inch standard tires on the 1931, so narrower wheel well. 5:50 inch tires on the 1932 , wheel wells are then made to accommodate the new wider 18” wheels, don’t have 1932 brackets to compare with 1931 brackets though.
JACK
