#481886 05/21/23 07:19 PM
Doug_L Offline OP
Hi,
Can someone tell me how many, and where are the freeze plugs on a 206 engine. Its a 1933.
I only see one below the manifold. Are there more, and can they be replaced without removing the engine?
Thanks,
Doug Ledonne
There should be one at the back of the block. Kind of hard to see. May be visible with the floor boards off.
Frank
1934 Master Sedan
Doug_L Offline OP
Thanks Frank.
With the floorboards out I could reach up and feel it. But it is behind the firewall and the only way to get to it would be to remove the engine or cut a small part of the firewall. Neither seem like a good idea.
I'll leave it for now...
Doug.
Doug Ledonne
