#481823 05/18/23 06:23 PM
verng Offline OP
I have a 27 or 28 doodle bug I am working on and I cant get one rear wheel off. I made a puller out of a hubcap with a 1/2" grade 3 bolt in the center. I tighten it on the hub and used a impact 3/4 to tighten it but it wont break loose. I rotated the wheel and tapped on the drum all the way around several times to no luck. It has wood spokes so I dont want to put heat in the center. Any ideas???? It has a 1 1/2 ton rear end with a 1927 engine and 3 speed trans
Here is some info about wheel pullers: https://vccachat.org/ubbthreads.php...heels-with-wooden-spokes.html#Post467682
Hope this helps. Dean
Loosen the center nut a turn or two and reinsert the cotter pin. Drive around the block, turning lots of corners. The wheel should be loose when you get home. This usually works.
verng Offline OP
Well I got the wheel off. I made a puller with a old hub cap. Drilled a 5/8 hole in the center and welded a 5/8 nut on it and used a 5/8 x 2" bolt. It took a breaker bar with a 4' long 1" pipe to break it loose.
Support The VCCA!
Member Photos
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
Who's Online Now
1 members (BearsFan315), 193 guests, and 23 robots.
Key: Admin, Global Mod, Mod
Newest Members
GuySeward, johnn76, jake55, RoadsterDude, 46CoupeJess
17,887 Registered Users
Today's Birthdays
woodbutcher
Forum Statistics
Topics57,943
Posts422,318
Members17,888
Most Online1,133
Jan 22nd, 2020
