rear wheel removal - 05/18/23 10:23 PM
I have a 27 or 28 doodle bug I am working on and I cant get one rear wheel off. I made a puller out of a hubcap with a 1/2" grade 3 bolt in the center. I tighten it on the hub and used a impact 3/4 to tighten it but it wont break loose. I rotated the wheel and tapped on the drum all the way around several times to no luck. It has wood spokes so I dont want to put heat in the center. Any ideas???? It has a 1 1/2 ton rear end with a 1927 engine and 3 speed trans
