It sounds like your Radiator is now clean and you flushed out the block & put in a new water pump... But did you make sure the baffle, behind the pump was in place...?? and do you have a functioning 160 degree thermostat installed..?? ....those are a few things that might cause overheating, after all that you have done....
I wrapped my exhaust pipe, under the seat area, with that fabric exhaust wrap insulation that they sell at the auto parts store....
I set my octane selector, on my 1934 master, with the 207 engine at 8..... I was advised that this modern gasoline requires that the selector be set at 8-10 I hope this helps... perhaps more knowledgeable people will advise you...
