#481841 05/18/23 11:12 PM
Anyone know who might have stock of CHEVROLET 1925-31 3-SPEED OVERHAUL KIT. Everyone seems to be out of stock
According to Gary Wallace they have stopped production. If your counter shaft and reverse idler shaft are not too worn you can get bushings to fit. I used the main shaft bushing, (order 3), and then the counter shaft bushings from the Filling Station. You will have to cut the main shaft bushings to size and do a little reaming for the reverse idler shaft.
Thanks for your reply. I thought that may be the case.
