Poppy48 Offline OP
Howdy folks!
Long story short, I am looking for specific and up-to-date recommendations for gear oil in an original 3-speed inside my 48 Stylemaster. I have the manual which recommends 1& 1/2 Pints of 90W "Transmission or mineral oil lubricant, or all-purpose/universal gear lubricant."
The only thing I have been finding online is decade-old conversations about how GL-5 is bad for the brass, and that GL-4 is what I want. The problem is, I am not finding GL-4 really anywhere. I have been calling around and discussing with some of the local folks I know who have knowledge of these sorts of cars and they are mainly recommending things like this...
https://www.napaonline.com/en/p/RPO01300?impressionRank=6
which do indeed have very specific information about how they are a substitute for GL-4 and GL-5 (Strangely) and are safe for yellow metals like brass.
Thoughts?
Side questions:
Pulling the plug off the rear-diff and transmission (filler plug), at what level should the oil be when cold? I have been told an inch below the bottom of the plug for both (Again, transmission filler plug). Sound about right?
Today's GL-5 oils do not have the high sulfur levels that would damage brass synchronizers. You are correct that it is difficult to find GL-4 only oils these days.
Any 85w-140 gear oil will work well.
There is lots of guidance about the "best" oil level. Some say 1" below the fill hole, some say 1/2" below, and some say you should just be able to touch fluid with the tip of your little finger when you stick it into the fill hole and bend it.
I typically fill until it is just ready to run out.
I have used GL 5 in my cars for the last 50 years with no problems.
I do not worry about the GL part of the oil but use the 85/140 oil and fill to just before it spills out of the fill plug and top up when your little finger doesnt reach oil. The same applies to the differential.
