Anyone ever install one of these? I am installing one on my 1948 Chevrolet Fleetmaster Coupe. The plunger that moves out when you pull the emergency brake on is spring loaded out. It seems to me it should be spring loaded in. The spring on the plunger(inside the unit)is so strong it overcomes the vacuum. Has anyone had one of these apart or know anything about them or have one that works? The instructions show an external spring from the hand brake lever to the plunger on the whistle, but I don't see how that spring would push the plunger in when the brake is released. I have all the parts shown on the Instruction sheet and everything was in the original box. I think the whistle was assembled wrong and the internal spring should the plunger in not out. Anyone have any ideas or info?
Thank for any help,
j7l2
