#481552 05/10/23 10:41 AM
WG1 Offline OP
Wanting to replace the instrument glass on my 47, not sure how to do this without wrecking the trim. It looks like its folded over and pinches the entire unit and to get the glass out it needs to be pryed apart????Help!
Thats is how it is done.
WG1 Offline OP
I don't see anything here?
Could you post a picture of the back side of the cluster? I need to refresh my memory as it has been 12 years or so since I did mine.
I am pretty sure I uncrimped the curved end that butts the speedometer as that is hidden when put back in place. I used very small pliers, needle nose, and worked small sections at a time. Also make several passes and un-bend a little with each pass until the glass will slide out.
Russell #38868
'48 4 door Fleetline
WG1 Offline OP
Yeah thats the only way this thing can come apart. I thought I was doing it wrong but I taped it out alittle aggressive to get it moving and broke the old glass. Just need to be more gental with the newm LOL Thanks for the confirmation.
