#481525 05/09/23 03:58 PM
Edmond Offline OP
Hello,
The bendix spring of my starter is broken. i have one to replace it.
Do you know if there are special bolt which could broke before the spring to fix the spring ?
Thank you for your help.
E9755680-C236-47BA-B1C4-AFB444307439.JPG F628E3EC-2B81-4D42-BC58-DA4515E7EFD7.JPG
Edmond
Edmond #481527 05/09/23 04:26 PM
the springs will fatigue and brake in time. not uncommon.
there should be a collar and screw on both sides of the spring.
when i recently rebuilt my starter i bought a completely new bendix assembly with the new spring
Edmond #481529 05/09/23 04:58 PM
I agree that this is not an unusual failure over time. While the bolt is not special except for maybe the length, the locking washer is somewhat unique. One tab bends down into the housing and the other tab is bent up to hold the hex of the bolt.
I would check to make sure that the threads in the housing are usable.
Edmond #481530 05/09/23 05:09 PM
The correct length is critical as just 1/8" too long and it will bottom out causing the spring to actually be loose.
Edmond #481533 05/09/23 07:12 PM
At least one is a special bolt with a locking washer/tab. I will post a picture of them tomorrow.
Edmond #481546 05/10/23 09:31 AM
I would say they are both special bolts as they would be hard to find. The part numbers have been superseded many times and the ones shown don't match my 32 catalog or my 34 catalog and the catalogs don't match.
I would think finding them locally would be best but if you can't send me a private message.
Edmond #481547 05/10/23 09:39 AM
I'll add that they seem to be hardened. I only know this since both in my starter have broken. I suspect that the previous owner used regular bolts that were cut down and were likely not hard (strong) enough. Both times required a trip to the machine shop to have the bolts drilled out of the shaft.
This post is guaranteed to be 100% content free!
'31 Special Sedan
Edmond #481555 05/10/23 12:20 PM
Edmond Offline OP
Thank you to all for your answers. I adapted a 5/16 24 bolt to get the correct length and that seems to work with the new spring
Edmond
1 member likes this: Dave39MD
Edmond #481609 05/12/23 10:40 AM
Edmond Offline OP
@ Dogbreath
In the contrary, I think the bolts are foreseen to broken before the spring to protect this one.
Edmond
Edmond #481630 05/12/23 06:06 PM
One of the bolts has a pin on the end to lock it onto the shaft. I think that was the end coming from the armature. Both bolts have a somewhat special retainer and a low profile head. A friend had two of the jars that had all the different bendix bolts. When my starter bendix bolts broke he gave me a set. They are still working on the starter. Originally the bolts were zinc coated.
