Posts: 335 |
Does anyone happen to have any brake cylinders, and a master cylinder, brake line Junction block. Thanks, Greg - oldie62
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I have some fittings and a used master cylinder from a 52 std shift sedan. The master would probably need to be sleeved as it was from a parts car. Wheel cylinders may be available from parts houses but if you are trying to stay original again unless well cared for NOS again sleeving will most likely be needed. The std and PG do not use the same master cyl.
They do not make 1949 and 1950 wheel cylinders. Thet sell you the 1938-1948 cylinders which are slightly smaller in front and larger in the rear.
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
The Filling Station and Chev's of the 40's sell them.
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I have a NOS Delco left front cylinder. you can e mail me bwbugay@aol.com
