#480948 04/23/23 06:54 PM
I started on my '37 Coupe over twenty years ago, other projects popped up and the coupe got put away. I now have time to finish it up. I have run across a few parts that are a mystery to me and was wondering if someone could identify them. Also I could use a diagram of how the brake lines are connected, front and rears and in between. I will be installing the two piece windshield shortly and was wondering if I am to put the molding in place first, over the lip and then slide glass in the molding, whether or not that is possible. Appreciate any input, thanks[Linked Image from vccachat.org]
Become a Member!
mitch2023 #480952 04/23/23 08:53 PM
Mitch,
I don't know about the bracket with the 4 bolts, but the offset link is part of your starter linkage. The hollow end slides over the pin of your starter switch. The fork end attaches to the cross-shaft portion of the foot operated starter pedal. Good luck.
mitch2023 #480957 04/23/23 10:25 PM
The shop manual shows the brake line routing.
The body manual describes the recommended factory process to install the windshield.
Installing the windshield is a 2 person job at least for me. I prefer to put the weatherstripping around the glass. Then I use a cord to roll the weatherstripping into the frame. There are lots of YouTube videos about installing glass in classic vehicles.
35Mike #480979 04/24/23 01:22 PM
Thanks for the info
35Mike #480980 04/24/23 01:24 PM
I thank you, given some time I have couple other pics, maybe you could identify for me, will post later
